The LS2 in the new Corvette is not all that much different from the LS1 (structure/layout-wise). It's a very similar layout with quite a few improvements. Here are the specifics....taken from another car forum.
"pre-2001 LS1-
346 ci OHV V8 (3.898 bore x 3.62 stroke)
10.2:1 compression
202/210 @ .05" duration, .496" lift, 116 LSA cam
26.4 lb/hr injectors (28.6 in '98)
305 hp rating (f-body), 350 hp rating (98-00 corvette), 345 hp rating (97 corvette)
LS1 intake manifold
LS1 heads
LS1 block
2001(+) LS1-
10.2:1 compression
198/197 @ .05" duration, .478" lift, 115 LSA cam (worse)
28.8 lb/hr injectors
310 hp rating (f-body), 350 hp rating (corvette)
LS6 intake manifold (better)
LS1 heads
LS1 block (mostly), but ~17% chance of having the stronger LS6 block
2001 LS6-
10.5:1 compression
204/211 @ .05" duration, ..525" lift, 117.5 LSA cam (better)
385 hp rating
LS6 intake manifold
LS6 D-ported heads (better)
LS6 block (stronger webbing, better oiling, better bay-to-bay breathing)
2002+ LS6-
10.5:1 compression
204/218 @ .05" duration, .550" lift, 117.5 LSA cam (much better)
405 hp rating
LS6 intake manifold
LS6 D-ported heads , longer & lighter valves
LS6 block
2005 LS2-
364 ci OHV V8 (4.00 bore x 3.62 stroke)
10.9:1 compression
204/211 @ .05" duration, .525" lift, 117.5 LSA cam (same as '01 LS6)
32.5 lb/hr injectors (better)
400 hp rating
LS2 intake manifold (slightly improved flow, runner length redesign for more mid torque, 90mm throttle body)
LS2 heads (duplicates of '01 LS6 heads)
LS2 block (LS6 + larger bore, redesigned oiling system, and various sensor relocation, 15 lbs lighter)"
Now, for the LT1. The biggest difference between the Corvette LT1 and the F-body LT1 is that the Corvette got 4-bolt mains, and the F-bodies got 2 bolt mains. The accessories are also on the driver side, whereas the F-bodies have them on the passenger side. Other than that, the engines are identical. Except of course, the exhaust manifolds. Any F-body LT1 that was replaced by GM got a 4-bolt main replacement.
The LT4 engine was found in the 1996 Corvettes...I'm pretty sure any 1996 Corvette with a 6 speed got one, along with the Grand Sports. They were also found in many of the 1997 SLP Camaro SS's and Firebird Firehawks.
For differences between the LT1 and LT4, go here:
http://www.grandsportregistry.com/lt1vslt4.htm
