glue dent removal..
i saw these kits.. its not the PDR kits that the pro uses but like a glue system that supposely remove dents. anyone tried these? does it work at all? or does it just push out the dent but still leave a mark?
I'd rather have the dent.
There is a large risk of the glue removing paint when attempting to pull the dent.
Spend $35-$50 to have a professional remove the dent.
A friend of mine is using it to do PDR over here in the UK. Most companies are using the normal methods over here. The hot glue kit that my friend uses is the same as Honda UK use at the plant on new cars. From the work he has done on my cars in the past, it works really well on small dents and ones that you can not access from behind the panel. Double skinned etc. It alows dents that other PDR guys will say need filling and repaint to be done. I dont know if the quality of kits differs, but from what I have seen I would not call it useless or works slightly. I had 100% results when it was used on my old concours car.
For larger or dents able to be pushed out from behind he still uses the normal methods.
A friend of mine is using a hot glue based kit to do pro-PDR over here in the UK, using it alongside the standard kit. Most companies are using the normal methods over here. The hot glue kit that my friend uses is the same as Honda UK use at there plant on new cars. From the work he has done on my cars in the past, it works really well on small dents and ones that you can not access from behind the panel. Double skinned etc. It alows dents that other PDR guys will say need filling and repaint to be done. I dont know if the quality of kits differs, but from what I have seen I would not call it useless or works slightly. I had 100% results when it was used on my old concours car.
