glaze, wax, sealant- when to use?
gtmustang00
what colors or situations would you use a glaze, wax, or sealant?
i have:
clearkote red moose machine glaze
clearkote carnuba moose wax
poorboys ex p sealant
2 more questions, would you apply those by a wax applicator or the pc 7424? What pad and speed?
the other question is i also have the optimum poli seal. When would i use that? Use a wax applicator or pc 7424? What pad and speed?
Would a blue pad be ok for applying these if i use the pc 7424? Or should i get a different pad? I'm ordering more stock in the next few days.
thanks!
The Red Moose Machine Glaze (usually referred to here as RMG) would be applied, er, by machine, rather than by hand, although Clearkote says it can be applied by hand.
You've got some overlapping products there, the Poli-Seal is an all-in-one, polish and sealant, which I'm sure can be applied by hand but you'll get better results by machine. You could follow that with the CMW or the EX-P.
The RMG is a fine polish, which would be followed by the CMW, I'm not sure the EX-P will bond over RMG. Please be careful on your trim surfaces with the EX-P or it will stain them badly.
yes you can. most do it to have the durability of a sealant while the wax adds more depth and gloss, wet look
