Automotive formulated glass cleaners use IPA as the base solvent.
Several things should be addressed when formulating of a glass cleaning product.
Such as using the correct surfactant in the formula that will increase the ability of the product to 'cut" plastizer deposits, smoke deposits, etc.
These are important, however, the use of some surfactants that may be fine for cloth, vinyl, etc, when added into the IPA formula, often will create permanent "spotting" of the dash material if it is warm when the product drops on it and is not immediately wiped off.
Glass cleaners formulated for household use will clean glass, however, most have a percentage of ammonia in them and that, from time to time, may do damage to the vinyl parts as well, under the right conditions.
A quality formulated glass cleaner will also have at least one other of the "alcohol" solvent family, blended in in small percentages, to allow a longer dry time or a shorter dry time.
Lots of things to produce a quality cleaner, besides just IPA.
Grumpy
