autobahn said:BTW, IMO, Z7 is WAAAAY too expensive to be using with a foamgun.
You'll be spending nearly $9 on each wash.
I KNOW what you're doing wrong, you're diluting your wash solution way too much. Somewhere between 60/40 and 80/20 shampoo:water ratio is where you want to be for optimum pickup by the straw. 2-3 capfuls of Z7 is not going to create any foam at all. REMEMBER: the foam gun is mixing what's in the chamber with a good amount of water.... The settings on the foam gun are mixing what's in the chamber with water, so on setting 1, 1 ounce of what's in the chamber mixes in with each gallon of water, so think of that as 4 capfuls of Z7 in a nearly-full 5gal bucket of water, which is the recommended dilution for Z7 by zaino themselves. If you dilute the chamber solution to 50/50, then that same bucket would only have 2 capfuls of solution.....
The point of the foamgun is not to conserve shampoo, therefore things like Z7 are prohibitively expensive in the foamgun. Beyond that, I see really no reason to use expensive shampoos like Z7.
BigJimZ28 said:
I divided the FG bottle into fifths and filled it 1/5 with Z7 and the rest with water and it still produced a lot of foam with the pin pulled to the left with one hole still showing on the right. It might be like 2oz.
Setec Astronomy said:I don't know what that is on the II, but on the I it's 4 oz/gal. .
Setec Astronomy said:Fluxy, what I do is use about 16 capfuls (actually, I measure by the ounce, about 5.3 oz, or a third of the bottle) in the quart foam gun reservoir, and go with the middle hole (I don't know what that is on the II, but on the I it's 4 oz/gal). Of course, that works out to the Zaino recommendation of 2 capfuls per gallon of wash...and as you noted people seem to use a lot less than I do in their foam guns.
How is that Foamaster II, BTW? If I had it to do over again I think I would get that one instead of the brass one.
ZainoStore said:#2 Mix one cap full of Z-7â„¢ Show Car Wash per gallon of water in a clean wash bucket.
Mindflux said:If you check Zaino's page they recommend 1 capful per gallon. They must have ultra-concentrated the wash. Because my wash from a few years back says 2-3 cap fulls per gallon and now their page says otherwise (I'll have to check my newest Z7 bottle).
Setec Astronomy said:Didn't we just go through this in another thread? My newest bottle which I got last year still says 2-3 capfuls. http://www.autopia.org/forum/detailing-product-discussion/65596-zaino-z-7-wash-questions.html
Mindflux said:We did go through it before. But the page says one thing and the bottle another... dunno.
Setec Astronomy said:I feel your pain, brother....
