Getting Spots Out Of And Polishing Aluminuim Diamond Plate?
What have you try in removing them? If you haven't try any metal polish like something from a auto parts store like Mothers then, try looking into the BLACKFIRE Aluminum Polishing Kit or any of it's components which aid you in removing the spots.
As long it's surface rust, the BlackFire Heavy Cut Aluminium Polish should remove it for you. When it does then follow up with the BLACKFIRE Fine Cut Aluminum Polish to finish it up. Remember to always test the metal first. Once you use the Heavy Cut Aluminum Compound you are committed to doing the whole surface because you cannot spot polish metal with a heavy cut polish.
I've used Mothers Metal Polish and an old wool pad on both a Rotary and RO polisher to get fairly serious stains out of diamond plate. You won't remove the pitting but chances are that everything will be so shiny that you have to give things a second look to notice many of the blemishes. I hear great things about BlackFire's metal polishes as well. That will be the next polish I try.
