Garry Dean's The Perfect Wash - Garry Dean - Tampa, FL - Premium Custom Detailing
Garry Dean
Garry Dean Quality!
Here it is! The BEST way, IMO, to execute the traditional wash method.
No more two bucket method (2BM)... No more dirt and grime separation devices...
1 bucket, ultra plush microfiber towels, The Perfect Soap, and Garry Dean's The Perfect Wash!
Check out the video I shot. Let me know if you have any questions!
I truly hope this will benefit those of you who are reluctant to switch to the Garry Dean Wash Method (rinseless method). Some people just don't want to switch, so... I fixed it!
Thanks for watching!
This is awesome. I'm not the only one who's come to realize that instead of using the two-bucket method with grit guards to reduce the likelihood of re-introducing dirt, using a fresh towel once for each panel never introduces dirt at all. I started doing this back in 2001, when microfiber towels were pretty scarce. So instead of microfiber towels, I had a stack of wash mitts. Same concept, different twist. Whenever I told others of using multiple wash mitts, they thought I was totally OCD. Who's laughing now? :)
Thats right! OCD for life!
haha. Nice. I have a pressure washer, but it sucks. How did you get that foam cannon assembly to fit on your pressure washer nozzle? I have one that basically hooks up to a regular hose thing (Quick connect style).
Anyway, video looks good. Thanks for the tips and info.
Ok I'm a fan of Garry Dean, lol now Garry in this video you have the SET UP quite a few folks have been looking for, need a video showing how you went about setting up tank/Drum to Karcher as well as fittings & hose needed, This would be a great help Thanks in advance.
Its pretty simple, really... I was given that 15 gallon tank a few years ago by a client who was going to throw it away. I drilled a hole in the bottom of it and found a fitting at Northern Tool that I put in that has a 3/4" hose bib on it and a gasket inside and out to make it water tight. The Karcher K2.360, 1.25 GPM pressure washer comes with a very cheap plastic quick disconnect system that is pretty much garbage. I have an extra 25ft hose extension and I got the foam gun and karcher fitting on amazon. The tank has a lid on the top that I remove to let some air get in and then gravity feeds the pressure washer.
Hope that helps.
I like it! Great video. I also like using a pressure washer (when possible). And I also prefer using MF for hand washing way more than a mitt or sponge too.
Hope that helps.
That may help alot Thanks Garry
Hope that helps.
Do you remember what brand that foam gun is?
By the way, thanks for this video and method! It will be my new go-to way to wash my car!
When will your soap and towels be on your site?
No one. It is just taking a known method and pitching it a new way. Any wash method is greatly enhanced with a good power washing including a rinseless. For example, the Absorber is just another reincarnation of the chamois and now there are lot of glass towels that are really just a chamois called a glass cleaning towel. It is about marketing and that is not necessarily a bad thing.
I think you quoted me out of context. I agree about what you said regarding a pressure washer. At the same time, that wasn't the point I was making: the 2 bucket method only reduces the likelihood of re-introducing dirt, while the 1 bucket method + not reusing the wash medium effectively never re-introduces dirt. I think the latter method would be better than the 2 bucket method even to the average joe who doesn't own a pressure washer.
I understand your point that you believe one mitt never dipped it better. I am not sure if there is a practical advantage given the car is pressure washed well but I feel there is more to the process than one specific aspect. Some just rinse the mitts with a hose without a second bucket so this is another variation.
For example, I feel it is safer to wash the door in sections (upper, lower, rockers) rather than washing one door from roof to rockers in one swipe without rinsing or changing mitts if no second bucket or mitt rinsing process is added. If you wipe 10 linear feet without cleaning/changing mitt or wipe 5 linear feet with a cleaner mitt which is safer?
I also prefer mitts because I can control the pressure against the paint better than microfiber towel. A mitt has two sides so there is the option to go over twice (one lightly, then flip with another pass). It is harder with mf on vertical surfaces because you have to push more against the paint.
Also, a good wash process should be combined with a good dry process such as using something like the Master Blaster. It is also about not using detailers all the time since every time you touch the paint there is a chance to mar.
I too would wash *VERY* small sections at a time, rather than an entire panel. But I figure that's what Garry means when he talks about tweaking the method in whatever way works for you.
I'm undecided about the mitt vs. towel question :confused: I don't see many MF mitts that are to my liking...can't seem to find the plush blue ones I like so much. My white ones have nap that's too long (just my preference) and my gold colored ones (Pinnacle label IIRC) leave a lot of lint. Overall I'd like to use a mitt for this, probably filled with the IUDJ solution, but it'd have to be the *right* mitt. And I'd want a *LOT* of 'em...hate to buy a few dozen of the wrong ones!
Garry- Is your preference for low-gpm pressure washers primarily a matter of water conservation? I always leaned more towards a high-gpm/low to moderate-psi approach.
Great point Al. The smaller the wash area you work, less the chance that you're spreading grime across your finish. The more that accumulates into your wash media during the wash stroke the more you're apt to marr the finish. Plus the lubricity decreases too.
My new chrome polish, soap, tire gel, and the microfibers should be on DetailJuice.com by this coming Wednesday evening.
I love this technical talk... Some people always think they have a better answer, and try to find a way to knock a product/process based on principal alone. I find it comical how big a debate the smallest things can be.
The bottom line here is, you can spin this method how ever you want. I stated in the video that this is the method I prefer and all of this is MY opinion. There is also a caption in the video that says "Feel free to add your own spin to this method."
I personally DO NOT do maintenance washes a part of my business. Instead, I have developed my own product line to assist people in doing the maintenance themselves. If I did, Id do it just like in my video...
My question is how many wash mitts did you need for a mid size car? Thanks.
Multiple wash mitts make total sense if the people think about it. A wash mitt can easily gather up dirt and instead of trying to wring it all out, just simply use another one. I have a load of them just like a golfer would have a ton of golf balls. If anything it could be for saving time as well. Just grab another mitt as you're working your way along. I think 3 to 4 mitts generally does well on a normal sized car.
