Frozen DP Four-in-One?
CharlesW
The Rainmaker
Somewhere between Florida and Ankeny, my 4 in 1 was frozen while in transit or at a UPS terminal. It wasn't on my front step 3 minutes so I know it didn't happen here.
Anyway, it had ice crystals when I removed the cap. I let it thaw ovenite and poured it out into a clear container. I purposely didn't shake or agitate the bottle to see is there was any separation. There was none. So far, so good.
I have read that the DP 4 in 1 has a citrus smell, this does not seem to have much odor at all, but what it does have, I wouldn't describe as citrus. Since this is the only bottle of it I have smelled, I have no idea if it is normal or not.
Could the freeze/thaw cycle affect the fragrance ingredients?
Would the freeze/thaw cycle be likely to affect the overall performance of the product.
It looks fine and if I hadn't read about a citrus smell, I would never know it was missing. (I read too much. :))
The question after all that garbage is:
Is it most likely that it is OK to use?
My thinking is yes, but my thinking is sometimes a little messed up.
Charles
It seemed like this question could use an answer. :)
Freezing didn't seem to have any bad effects on the DP Four-in-One.
I did check with DP and they didn't think it would be a problem and I think they were correct.
I used it Friday with no problems.
It's probably not a good thing to do regularly, but at least it can be shipped in freezing temperatures.
Charles
