Beemerboy
Just One More Coat
I have a friends Ford F150 pickup coming up next week...he was by yesterday evening so that I could have a look at the rims..polished aluminum that are going to need some high speed polishing...he asked if I do engines...No problem...the motor is dirty but not super bad..I've worked on worse....then he said you can't get the spark plugs wet..what?.... I asked why?....bare with me here...... he said that each plug has a separate coil over the top and if it gets wet can cause a short or something like that...I'm thinking this is a 4x4 off road type of truck, surely going threw creeks and rivers and wet weather driving would cause some water to fly up in there...just a guess
So I'm asking fellow Ford truck drivers for some advice on this one...anything to be concerned about here?
The process that I use for engines is APC, brushes-a-plenty and low pressure rinse with water then a water based dressing.
