imported_Jakerooni
This one came in a complete friggin mess. It's a construction companies feild truck. There was cement dirt mud... well you name it it was probably in here. The rubber floor was going to make it easier I thought... NOPE! once I did the intial wipe down the cement was ground right down into the rubber. I figure this was going to be a long day.
Even in the door... Do they have no shame.. :hairpull:
yep even the back was beyond trashed....
So I started by heating up the extractor. "Now jake there's no carpet in that truck at all why are doing that?" I needed the heat to deep clean the rubber floor. I started with some citrus foaming cleaner. (actually I think I started with some APC that didn't work so I played around until I found something) and then started scrubbing the dickens out of everything and then some. Finally it started to come clean.
After a few more hours on what is usually an easy job (no carpeting usually means quick clean up) I got it done.
Someone did ask me if I dressed the floor becuase of how they came out and I remind them the first rule of rubber flooring is never dress it. I just scrubbed the hell out of it and use good techniques to get it back to that condition.
