For those with a CR Spotless or any DI setup
pingable
Is it truly no towel free......
Anyone using it in the manner of final rinse and no towel touching the surface.
Overall long term finish with no towel - just air dry method ?
I have only been successful with that by blowing the car off with my Air Force Blaster (Metro). I suppose pressure washer like in the CR video or rinsing it endlessly...but with what I would consider a normal rinse, no, you'll still get spots if you just leave it.
The new addition has very soft paint. I was leaning on usual was methods....and or QD in the drying process &/or just the cr spotless to use for the whole wash process but a added + would be I would not touch it when drying, trying to keep marring to a minimal.
It seems to be soap and/or dirt (or perhaps hard water from the pre-rinse) that comes out of crevices when you rinse. If you can deal with the hassle/expense of changing out the CR filters often, you can try an extended rinse (or pressure washer, which I haven't done). My technique was to rinse with the CR, then blow out the crevices (since you have to do this anyway) and then while I was at it, blow off the rest of the car, which leaves a few drips to clean up with a towel.
This worked pretty well, but after a while it seemed like it made more sense to just do my whole wash with soft water from in the house, since I was blowing the rinse water, anyway. I'm sorry I seem to be rambling through this...but the CR, although very helpful, never got me to a "rinse and walk away" process because of the water in the cracks and crevices.
