Foggy Headlight
FDNY1075
I had a customer drop off a 2007 Chevy Tahoe (Large headlights), and noticed that the passenger side headlight assembly has condensation on the inside of it. I assume the vehicle was bumped or crashed and the seal failed, but is there a quick easy way to fix this or clean it up? Drill a hole and let it dry out in the sun, then silicone it?
Any input would be appreciated!
Eli
I don't know how easy it is to get the headlight out, but I was told using a little IPA helps it evaporate faster.
Just take the light out and set it in the sun or just out to get some "fresh air"
Wouldn't hurt to get a new seals for the bulbs, if availble. It probably why its leaking.
instead of poking a hole, you could take out the whole headlight, (w.o the bulb) and lay it face up, the hole will already be there from where you insert the bulb...
