foamaster II not working?
bace
I just bought a foamaster II and tried it today. no suds or foam was coming out of the gun, only water. I checked the tube in the canister and none of the soap was traveling through it. I took the tube off to see if there was any clogs but there wasn't any. So I kept the tube out and tried the gun again but flipped the canister half upwards so the canister was on top then it worked perfectly.
any ideas why the soap wont travel through the tube??
thanks.
You have a blockage. I work for a company that is a distributer. The only reason they wont pick up chemical from the feed is a blockage somewhere.
yea the filter and tube wasn't blocked but I took apart the mixing part and cleaned all the openings and put back together and now everything works.
base- Glad you got it working. Maybe you oughta empty it out after every wash and run a little clear water through it....not that I usually bother doing that.
