Changeling
Does anyone have any experience using LC foamed wool pads and Menzerna Super Intensive polish with a rotary?
Changeling
Changeling
SuperBee364 said:I used that combination (well, close to it; I cheated and used my new SIP 3.02 I got from England) on the roof of my Wife's Sequoia when I switched the LSP over to Vintage last month. Purple LC Foamed Wool or Edge 2000 Yellow wool used with SIP is my new go-to combination for moderate correction. Either one of these pads (with the nod to aggressiveness to the Edge yellow) when used with SIP will not only give you great correction, it'll give you a darn fine finish. I used the foamed wool on half the roof, and the yellow on the other half (which had some pretty bad scratches). The foamed left me with just the slightest amount of compounding marks and holograms. The yellow was a bit worse, but still not bad at all. A quick pass with 106ff and a blue edge wool pad cleaned it up very nicely.
The correction rate was also very fast. I found myself not needing to go over each area nearly as many times with the 3.02 and the wool to achieve the needed correction. I bet I saved darn near an hour's worth of time on that acre of a roof.
porta said:Must get me a couple of those foamed wool pads...
porta said:Ryan, can you get the smaller wool pads as well? Where can I get those smaller pads
5" and 6" (IE where can Ryan buy them and send them to me?))
rydawg said:Why do I feel responsable for this thread:rofl I started this big wool trend and now with the SIP 3.01 and 3.02.
Superbee you have some of the best products now and your car should look killer when done.
Wool will leave marks reguardless. Wipe all the oils down and put in the sun or halogens.
If I were to do your car, this is what I would use on rotary.
3.02 on an orange LC pad
106ff on a white LC pad
check work and it should now be super bright and clear with no trails at all and be 100% swirl free. Chrysler has nice hard paint that I love working on personally.
Put your new wax on and it will be one of a kind!!!!!! Put you car in a parking lot of a hundred of the same colored ones and I bet you will pick it out of the bunch in an instant.
Wool is great stuff, but I only use it on the more difficult cars. Edge does make great wool pads though. I did try the purple wool out and it is a nice pad also. I still like Presta polishes on wool though. A couple people I have taught like Presta better on wool too. 3.02/3.01 kicks butt on orange LC foam though.
