Foam pad or MF applicator for AIO and SG?
Blackmirror
I've tried both and seem to like the foam pad better. I've used the foam pad for SG only so far. Not sure if its good for using AIO. Shouldn't the MF applicators be used for AIO for cleaning rather than the foam? What applicators do you guys prefer for aio and sg?
I use MF for AIO, foam for SG. But I wouldn't hesitate using MF for SG, but probably wouldn't use foam for AIO because MF holds moisture better and helps pick up dirt.
I prefer foam for both. I'm not crazy about the uneven texture MF apps get after doing a few panels. Sure, you can rinse the entire app after each panel....but what a PITA.
MF apps also require a lot more effort as they tend to grab your paint surface when applying product....especially with AIO where you apply a little more pressure than KSG.
I agree with Intermezzo. I use foam for both products and never had a problem. When your all finished the foam applicators are much easier to clean as well. :up
I've asked this question before but no one answered.
I use MF applicators for everything.
The thought of using one of those plastic foam applicators scares me. It really looks like it will scratch the paint. I've never had the guts to try one.
Has anyone experienced scratches from their foam pads?
I've had thoughts about foam pads, as well, but felt that they might scratch (especially if there was a stray piece of dirt picked up by accident).
I've stuck with the supplied mf covered foam pads that I got with my Klasse Concours kit and like them a lot. I find that they are just as easy to wash as mf towels.
