Foam Gunswith or without pressure washer
mose
So.....do the foam guns require use with a pressure washer or just straight out of the hose?
this kind of foam gun hooks up to your hose...
autogeek_1994_80053299
How to Detailing Video - Foam Gun
And this kind hooks up to your pressure washer...
But notice that it requires a threaded pressure gun connector. You'd need an adaptor to use it with quick-twist type pressure guns.
Hi SuperBee364:
I saw a while back your video on the foam cannon . When to the same place you got yours but when I order the pressure foam cannon I got the one for the hose . They told me the part number I requested was for the hose type . I look at their web page and couldn't find the one for the high pressure . They change the item but kept the part number . Can you direct me to the place were you got the picture for the high pressure one .
PS : Love your new ride . Awesome color
Cheers ,
Jean Paul
Jean Paul, I'm sure sorry for the confusion. For some reason, everypressurewasher.com replaced the Cam Spray Foam Cannon with the model that you received. To make things even more confusing, the latest word is that they have now changed *back* to the Cam Spray foam cannon. Although I can't confirm this for sure.
This link...Foamer Attachment Camspray is the exact model, but they want quite a bit more cash for it.
I'm hoping that someone that has ordered from everypressurewasher.com recently will chime in with what mystery gun they actually received from them.
UPDATE.
everypressurewasher.com has got their act together. They have the same cannon as camspray for less. I made the mistake of fogetting to cancel my order from everypressurewasher.com and recieved a 2nd foam cannon today. It is the same item.
Superbee, I took the chance and ordered the Cannon from everypressurewasher.com
I got it today and it looks exactly the same as the camspray ebsite picture, accept the little dial on the side is red on mine and not silver. Not sure if that makes a difference or not?
it came with 2 brass connectors.
Hope this helps everyone. I was able to get it for 80 shipped, not sure if that price is still in effect or not.
I wonder if Paul (walnuts) can chime in on the thread. One thing he did not like about this cannon was the small size of the plastic bottle. Did you or anyone else find something bigger that fit properly?
raadkins16 said:
I wonder if Pal (walnuts) can chime in on the thread. One thing he did not like about this cannon was the small size of the plastic bottle. Did you or anyone else find something bigger that fit properly?
Just use a 32oz spray bottle. Take your original siphon tube into your local hardware store so you can buy the correct size tubing. They sell by the foot and you won't need more than a foot. It cost me less than 19 cents after tax from Lowes.
Even a 2 liter soda bottle will fit, you just have to get longer tubing.
Yeah, that's what pretty much everyone is doing. I bought a 32 oz spray bottle at target, and used the siphon tubing off of an old dead electric pressure washer as the pickup tube. The original bottle is just too small.
