Flat -Vs- Curved Pads
cheapshot
Let me first tell you my experiences and maybe you could help me out. I only use the PC and I have only used Meguiar's foam pads. I have used one White Polishing Pad from SMP that I believe is a 7-1/2" LC Curved Edge Variable Contact (VC) Pad?
I am currently using Meguiar's polishing/finishing pads and they perform well for me. However I'm am looking for a pad that is more aggressive then Meguair's Polishing and not nearly as aggressive as the Meguiar's Burgundy or Red cutting pad. When I take out DACP and a polishing pad and try a section on a car, and see that DACP did very little improvement, I want to step up to a more aggressive pad, But not the Burgundy one it's way to aggressive IMO.
So maybe you guy's could help me find the right pad, orange? yellow? LC? Sonus? Edge? Buff & Shine? Curved? Flat?
I would like to know the differences between Flat and Curved Pads. Pros and Cons and what everyone prefers?
I could be wrong, But thats why I posted this. Speaking from my experiences as a beginner and what I think about it. I seem to like flat pads for polishing compounds and any swirl removal. When I was using the LC? curved pad I felt like working on the edges and tight area's were easier. Putting the PC up on edge felt right, and the pad had a nice contact. I think thats where the name comes from (Variable Contact) However I don't feel safe polishing with these curved pads, I could see using them for light cleaning, glazes, sealant waxes etc. where your not applying much pressure, and moving the PC on Edge wouldn't cause any problems.
fwiw, the only pads that I will buy in the future for my pc will be the smaller (6-.5") flat pads similar to the Meguiar's pads. I don't ever get nearly the great results from the recessed or 'curved' larger LC pads that I have as I do with my smaller flat ones. I.e...swirl removal and paint clarity. my .02
I also prefer 6.5" Flat Pads, But remember I only use PC. I'm sure 7.5" Pads are OK on rotary. let's see what others have to say maybe they will change my mind. I'm sure there are many VC or curved pad users.
Also any ideas for a pad that seems to be between Meg's polishing and Meg's cutting as far as aggressiveness? :nixweiss
LC VC pads were never designed with the PC in mind. I
believe this was just some gimmick by detail suppliers to
sell folks on something new.
If you are going to use a D/A or random orbital machine, you
need a flat pad that will provide you with maximum surface area
to effectively do work. Countoured or variable contact pads
are better served on a rotary.
cheapshot, if you're looking for more options, I would
suggest trying the Edge Pads. They offer a few more pad
choices over the Meguiar's line, and they are also availabe in
dual sided units.
Flat pads offer more consistent surface contact but the curved edge pads allow to easier transition from panel-to-panel.
The LC curved edge pads also fit the backing plate into a recessed space that automatically centers the pad & pretty much eliminates the possibility of the backing plate contacting a spoiler, mirror, or other exterior trim.
The LV curved edge pads also have significantly better velcro that the LC 6" & 6.5" pads but, as usual, it comes down to personal preference and the 7.5" LC pads work very well for me.
LC 6.5 Inch orange pad and Sonus Orange Pad. I use these and Megs pads. The orange pads are right between the Megs polishing and cutting pads for aggressiveness.
Steve thanks a bunch, Are both pads flat? or curved? Is one more agressive or are they the same?
Also would it be closer to the Meguiar's polishing? Because the burgandy is rather stiff.
Sorry for all the questions
I couldn't tell a difference between the Sonus and the LC in aggressiveness. The LC pad has a concave surface. The Sonus pad has a flat surface. The Sonus pad also has a recessed area for the backing plate to fit into.
They both are right between a Megs Polishing Pad and a Megs cutting Pad. They do what they are supposed to do. That is provide most of the cutting ability of a cutting pad but with a nicer finish like a polishing pad.
I only need to use my Megs burgandy cutting pad on really bad finishes now that I have the orange pads.
Steve thanks for pad advice I really appreciate it. I see you use the burgundy pad for really bad swirls, I just did a car I have pics up some where in the forum. Anyway it's black and I tried DACP with polishing pad 2-3 applications and it did very little :confused: (maybe they put steel in the clearcoat) :nixweiss So I used burgundy pad and and two passes swirls were gone, and I could then see what were deep imperfection that were not going to come out. Then I noticed the haze :scared. But ended up removing them after hour of playing around. Hazing is my main concern when stepping up the pad with DACP. I will give the orange pads a shot! Hoping they have just enough cut, and finish out like Meguiar's polishing pads.
Steve what product do you like using with the orange pads for swirl removal?
3M Perfect It III Rubbing Compound - orange pad
3M Perfect It III Machine Glaze - polishing pad
Menzerna Final Polish II - polishing pad (optional step, 3M PI III MG usually leaves a ready to wax/seal finish)
