First timer setup - Waxing with PC7424 4" pads?
lagvoid
I'm putting together a list of things I need to get started with the PC7424.
So far here's what I've got:
PC7424
6" counterweight (read that it helps vibration in the long run and they are cheap).
3.5" backplate
bunch of 4" orange and white pads from (4^^ Erasure Turbo Kits)
I've read to stay away from the yellow pads, but what about the green or blue pads?
What can I use to apply/remove Collinite 476s wax, instead of doing it by hand? The wax is a brick so I'm worried I won't be able to apply it with a PC7424.
I already picked up some Poorboy's SSR3 and SSR2.5 for the bad stuff.
I appreciate any input! Thanks
lagvoid said:
.....bunch of 4" orange and white pads from (4^^ Erasure Turbo Kits)
I've read to stay away from the yellow pads, but what about the green or blue pads?..........
Those should be just fine. The blue is actually a finish pad and you might want to check with Patrick at Excel where the green pad falls in relation to the white pad. There has been a lot of talk recently about the different densities of green foam out there and I don't remember where that pad falls in relation to the others.
lagvoid said:
.....What can I use to apply/remove Collinite 476s wax, instead of doing it by hand? The wax is a brick so I'm worried I won't be able to apply it with a PC7424..........
Using a PC to apply 476 won't be a problem at all. The 4" pad should scrunch down enough to fit in the tin of wax. If not another method I use is a 1" plastic putty knife to "butter" the pad with a small amount of the wax. Applying 476 thin is the key to easy removal.
As much as I like using a machine to apply waxes and even most sealers, to remove them I just buff off by hand with a quality MF.
Eliot Ness said:
Those should be just fine. The blue is actually a finish pad and you might want to check with Patrick at Excel where the green pad falls in relation to the white pad. There has been a lot of talk recently about the different densities of green foam out there and I don't remember where that pad falls in relation to the others.Using a PC to apply 476 won't be a problem at all. The 4" pad should scrunch down enough to fit in the tin of wax. If not another method I use is a 1" plastic putty knife to "butter" the pad with a small amount of the wax. Applying 476 thin is the key to easy removal.
Thanks for the reply, its given me much more confidence to go ahead and make the purchase.
I'll send Excel a message to see what pad they recommend using to apply the 476.
