wannafbody
wannafbody
I decided to break out of the mold and give a Makita twisted wool pad a shot. I devised what I thought was a safe plan of attack. I reached for a mixture of Mothers powerpolish and Megs #9(my MPP was thin so I thickened it up a bit) in order to prime the pad. This actually worked well at keeping the pad moist but did result in some initail sling. I then used a mix of OHC/MPP to cut the paint. I used my rotary at roughly 1000-1200 rpm to keep it safe. I didn't have much of an issue with shedding until I allowed the pad to dry a bit too much. Then it started to shed. The wool pad really does a great job of smoothing the edges off etching. I didn't remove all of it but I did make quite an improvement. It seemed to be much quicker and effective vs using a yellow cutting pad. I still need to do a final finishing polish to achieve a bit better gloss and remove some swirling. If you have serious etching issues wool can be a great tool in the hands of someone who uses some common sense and is careful. It wasn't nearly as scary of an experience as some here think.
