This is the CP LP pad.
I apply two 8" lines on the surface and work it in then turn on the PC at 3.5 to 4. side to side and back and forth. It seems like that on the 3rd to 4th pass the MIP is about dry. Does that sound right to you?
Does the pad look ok?
I then wipe off with MF. I have done this about 4-5 times. Area is very smooth but does not seem to be cutting the water spots or small scratches that much.
I guess I just need to keep at it more. Maybe I should of got a yellow pad too.
This is the area, I guess this angle is not giving a good look at the water spots.
TIA!
UPDATE
Not getting anywhere with the orange pad.
I went over this part 6 times and increased the speed setting on the PC to 5.
This is a area that has not been touched yet:
Looks pretty much the same....
Should I go with a yellow pad?
Thanks!
TIA!
UPDATE
Thanks!
