Today, I tried the rotary polisher for the first time. It was actually not so difficult as I thought. I was using a Vector polisher, finger pads from Lake Country, and 3M rubbing compound and SMR. I started with 1000 rpm, then all the way to 2000rpm. Only one spot got paint burn at the side mirror. I guess the main reason is not because of the spped, instead, because those mirror cases are made of plastics, not metal.
I found the most important thing I learned today is not adding any weight to the polisher. In that way, the polisher is much easier to control, and much less skip and cake building. And as many autopians said, tilting the polisher a little bit did help a lot too. Once I managed these, the polisher was controled with much less effort, and almost no residue left on the paint after the work.
The result is good, polisher sure took away a lot of defects I wasn't able to with bare hands. And the paint looks and feels really smooth after the wash. However, there are some marks (maybe from birds drop which left on the paint too long) still there intact. And they look more obvious than before since now the background is much clearer. Should I change to a more aggressive rubbing compound? Or should I try with a higher speed? (After I worked on the paint with 2000 rpm, I put my hands on the paint and felt it was a little warm, just a little).
All in all, it's a very good experience, and my 1993 Audi has never looked so good since i got it 2 years ago.
