bennylava
This probably isn`t anything new for most of you. May not be any point in creating this thread. But its a big deal to me. Cause I`ve been rooting around for a final answer to this problem for a long time. I`ve asked here a couple times, and I never saw a reply that dealt with what happens to the plastic headlights on cars, when you`re done restoring them. So maybe this is something a few people need to be aware of. After you polish out and refurbish a hazy set of headlights, basically they just start the degradation process all over again. Even with a coat of clear, its still only a matter of time. Cause many cars get that same coat of clear (or even better) from the factory. And they still end up having you cursing the automaker`s name. BUT if you use this once per year, you`re done. That`s it. Spray it on, and let it dry. Obviously if you`re not working with new headlights the sanding and polishing restoration process is still going to be necessary.
Link removed.
But the problem with doing that is, you only get to do it so many times, before your material gets thin and you crack it. I just ran into that issue on my Mustang. Now I get to buy a new set of headlights. The material apparently just got too thin, after only 2 restorations. On top of that, once you spray on some more clear, the problem can actually get worse when that clear begins to break down and wear off. Now you`ve got another level to sand flat, on the surface. Happened on my wife`s toyota. It wasn`t there the first time I restored the headlights on that car. There was just that annoying haze that had to be sanded off. So I applied a clear coat after all the sanding and polishing was done, and now a year and a half later, that clear coat is half eaten away and the haze is starting to return. So now this job is actually worse, because instead of just the haze, I get to level out the old clear coat as well. That`s if I don`t just chuck em in the garbage and buy new ones. And yeah I used clearcoat with a hardener. One of those one time use cans.
Link removed.
