filtered water? help
Chris..there are is 3 solutions...maybe just 2
1. Find a DI water supplier thats cheaper than Culligan...
2. Find a DI filter tank renter...they come and switch them out....aroung here it is about 60 a month to rent...good for 2500 gallons on a 2 tank system...they are as big as a house propane tank..
3. try a water sheeting agent like they use in tunnel washes...it may work may not...but worth a try...
Texas water is rock hard...when I was working in Texas...the water would not lather soap...it was so hard with minerals....
Al
Great subject. I have a 225 gal tank and I can and have washed 16 cars in a day (that is as many as I can do alone due to time not tank volume). I Sacramento it can get into the 100's in the summer and I find that I have to wash and rinse areas of the car as I go. Now I don't use any special water just the hose brand here. I have found that the soap I used in the summer somehow helped with my water spot issue (as in I did not have any issues) But I was using the Car Brite Wash and Wax AB. I think that you are using the same brand of products too. I would like to know more about the DI stuff though, and help me understand is this the same as what all of the car dealership guys have in the back of their pickups when they go from lot to lot?
Kenny
Softening the water a bit would help. This could be as cheap as the pwgazette water filters with softening cartridge. Larger more expensive ones like on TOL are available. Kent Marine has some Reverse Osmosis systems that would certainly work. You'd have to figure out if the wasted water would be worth the expense. Rinse aids like Cul-Mac sells seems to work good at sheeting the water . Using a pressure washer will almost certainly require the water going in to be highly filtered. The tiny drops it produces are hard to combat otherwise. This is why I don't use my pressure washer except on the dirtest vehicles.
Kenny
I haven't used the Car Brite Wash and Wax AB soap yet. I am using the regular Car Wash Suds....I think that is the name. I guess I will pick up some of it when he comes to town tomorrow.
I just have found that it actually works better than some of the other stuff that I have tried. Which would included the Meguiars Gold Wash, Simple Green Car Wash and some other store brand stuff. I too have to battle the sun and anything that I can find that will assist me with drying and no spots is for my best intrest.
Kenny
RO Systems are generally quite expensive and available more for people who don't have a direct connection to municipal sources. You only get 10 - 15% of the Filtered water, so there is alot of waste
Deionized Water is your best bet, look for a local supplier. Otherwise Filters are your best friend. pwgazette or CR Spotless are a nice resource. Do a search for "Spot Free Water"
Take note softened Water is not DI water, so you need a good filtration unit or setup. Try using a TDS Meter for the solids.
If all else fails, get a canopy or shade!
