Ferrari Serie Speciale in Rosso Corsa
Sizzle Chest
Well-known member
1993 Ferrari Serie Speciale 348 TS, Rosso Corsa, #52 out of 100 built
I had the privilege to work on this very speciale Ferrari the past few days. This is a 1993 Ferrari Serie Speciale 348 TS, Rosso Corsa, and is number 52 out of only 100 built. It is powered by a 3.4 liter V8 which made 312 hp. The transmission is a gated shifter actuated 5 speed manual. (very cool). This vehicle has the very rare and sought after F40 style sport seats in Connolly leather and carbon fiber seats tubs/frames/backs.
There is a HUGE car event coming up next month and the owner is going to show the car and wanted it ‘cleaned up a bit’. The doctor at Autodermatology was happy to oblige.
This Ferrari came into the surgery center for a paint correction, wheels off fender well/wheel/brake caliper detail and ceramic coating, exterior paint, trim and glass ceramic coating.
When the vehicle arrived I did an ONR wash. ONR was also used as lubrication during the claying process. A nano-skin wash mitt was used for claying. About a mile of CarPro ¼” red tape was used when masking off all of the trim, raised body lines as well as any ‘thin’ areas of paint that I found. Adam’s orange tape was also used in the wider areas.
Paint gauge readings were from a low of 2.0 mils to a high of 8.0 mils. I found out during the initial inspection of the vehicle that it was single stage paint.
The operating room was prepped and I got this Italian Stallion under the lights and ready for some dermabrasion!
Before pics/defects:
An area was taped off for the test spot. Rupes Duetto and a green Rupes pad along with HD polish was chosen to see what kind of results could be garnered. It was working pretty well, but not what I was looking for. I then switched to Megs M205 with the same machine and pad combo. BINGO! Just what the doctor ordered! I did, however, switch out machines to the Flex 3401. I felt like it was doing more work…since it is a work horse of a machine!
The compound stage of paint correction was accomplished with the Flex 3401, green Rupes pad and M205, along with the Rupes 75 and Flex PE8.
Final polishing was done with the Griot’s 6”, Rupes 75, Flex PE8 and CarPro gloss pads along with CarPro Essence.
(I burnt through a sh!t load of pads with the single stage paint…loaded them up pretty quickly and had to swap them out once or twice per panel)
The CarPro Essence really, really amped up the gloss on this paint! I could’ve left it alone after that and used it as an LSP, that’s how happy I was with the results.
The engine cover is one piece and louvers from top to bottom side to side. What a PIA. It was also filthy and had a lot of accumulated dirt, road grime as well as ‘the other guy’s wax’ in the slats. I attempted to clean them by hand and was getting nowhere quick. I broke out the steamer. I covered the engine with two of Autogeek’s Detailing cover up towels. Steam made short work of the gunk that was in those louvers. Wiped it all down and I was pleased with the results.
The door jambs were pretty dirty as well. They received a good cleaning and are now up to par for the caliber of vehicle they belong to!
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
Next up, ceramic coating! Pretty much every inch of the exterior was coated with BEEDS premium ceramic paint treatment. Glass, paint, door jams, targa roof and trim.
The wheels/wells, calipers were the next thing to tackle. The vehicle was jacked up and jack stands were utilized for safety. The wheels were pulled.
The wheel wells were scrubbed with 1Z APC and a stiff brush. Washed down with Sonax shampoo and rinsed. The calipers were cleaned with 1Z APC and then washed with Sonax shampoo and rinsed.
Fender wells were treated with Adam’s undercarriage spray.
The brake calipers were coated with CarPro Dlux.
[/URL]
[/URL]
The wheels were liberally sprayed with Adam’s wheel cleaner. Miscellaneous boar’s hair brushes and Daytona Speedmaster brushes were used. The wheels were then washed with Sonax shampoo. Tarminator was used on the built up tar as well as any adhesive residue from old wheel weights. The wheels were washed again and then clayed with a medium Nanoskin sponge.
The tires were shot with TufShine tire cleaner and their brush was used to scrub the tires clean.
The wheels/tires were Metro Master Blasted dry. The wheels were then treated to an IPA wipe down prior to coating. The wheels were coated with CarPro Dlux.
These original Speedline wheels came out like new!!! Excellent!
The wheels were then re-installed and torqued to the proper torque spec. (75 ft lbs)
The tires were dressed with CarPro PERL. 100% straight up.
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
The exhaust was cleaned with Pinnacle exhaust cleaner and brightener.
Glass was cleaned with Adam's glass cleaner and a dedicated glass micro fiber towel.
The interior was vacuumed via Metro vacuum and attachments. The interior leather was given a quick wipe down only.
The carbon fiber seat backs were given a wipe down, light polish with M205 via hand and then treated to Wolfgang Fuzion. They came out great and feel super slick! This work really brought out the carbon fiber weave! Brightened them up a bit too!
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
I’ve got about 22 hours into this detail and am happy with the results I achieved on a 23 year old speciale vehicle.
Thanks for looking and enjoy the pics!
