imported_Indy YZF
Does anyone know, or personally experienced, what a clear coat, that hasnt actually failed yet, ie, it hasnt peeled off anywhere, but might be on the verge of failing looks like upon close inspection under the lights?
Theres an area on the leading 24" of my hood all across, where I used to use a hood bra and developed some surface marring, that Ive done quite a bit of polishing to smooth out the scratching...Ive done a pretty good job in the most of the scratching is gone..
The area is smooth as silk, and very shiny....But, under close inspection with lights, you can see loads of tiny pinholes pretty closely spaced, in the surface. You cannot feel them at all. And unless its under indoor lights, it looks incredibly shiny and deep. So, whats causing this?
I know were' not supposed to trust those Marr-Hyde magnetic paint gauges, but it detects no difference in the depth of the finish there or elsewhere where I have not done any deep polishing.
So, does anybody have any idea what this is? The harshest stuff Ive used on the hood is 3M FI and Meguiars #2, applied with both an orbital, and just a tiny bit of work with a slow speed (1600 rpm) Wen rotary. And I havent really done much of it at all.
