Ex W/pc
Raven
I tried using PB EX with my PC (black finishing pad) today and loved the ease of use and the shine it left behind. My question is: I want to add a second caot of EX, can I use the PC again? Will adding the second coat using my PC take off the first coat?
I put on a coat of EX-P by hand, and then the next day put on a second coat, this time with the PC and a finishing pad with great results. Neither EX-P nor EX have any polishing properties so I don't see a problem at all doing it that way. Since both are sealants I'd let it cure for 24 hours first.
of course use the PC again. The only thing I apply by hand are "carnuba toppers" otherwise, I use my pc solely. Interestingly though, I put my EX-P on with a white pad as its thicker than most sealants i've found.
Thanks for the replies, I'm adding a second coat of EX by PC and then topping with P21s. Should come out looking very, very wet and deep.
