Heh heh thanks!
Actually, I used M83 with the Rotary with a yellow W-8006 pad first, but found it too gummy (on the trunk area), so I switched to M80 with the same pad. That worked well, but was still having a bear of a time removing the residue mainly from product buildup in the pad--so I switched to a cutting pad W-7006 and still M80 since the more dense foam absorbs less product. On the flat surfaces I just used the weight of the Makita, but on the borders of the taped off high points, I delicately applied the rotary with the yellow W-8006 pad and just tapped it against the surface removing tiny bits of oxidation at a time.
After removing the tape, I used a PC with the W-8006 pad and M80 to even out the now exposed paint areas--also very delicately, getting as close as I could to the edge without touching it.
I primarily used M80, and constantly checked the paint surface to make sure it wasn't getting too warm, especially on areas with the deepest defects.
So I'd say the process was more like:
M80 with Rotary x 1
M80 with PC x 4
I barely used M83 so I wouldn't count it as a pass. =)
Thanks for your feedback!
Richard
