Beemerboy
Just One More Coat
Edge Shmitt
Out of the package
The waffle weave foam feels like that of a finishing pad. The one thing that you notice next is the sturdy construction of the backing pad, which is made from yellow harder foam. The glue holding the two pieces together is very visible, and creates a very tight bond on the two foam pads.
The glove fits tight over your hand so that you feel like you will have good control over the mitt.
In the Soap and Water
I found that once in the soapy water this mitt stays snug on the hand which allows you good solid control over it. The white waffle weave foam had great absorbency that made it quite easy to get plenty of soapy water on the car and lasted for a few minutes or so while you worked the panels. What I did like was the ability to use this like a foam glove that allowed me to bend and push it into areas, like the corners of my rims, under door handles, etc.
One thing that it dose is saves time as you can move with the bucket down the side of the car quickly dipping and wiping. I didn’t feel like it was picking up a lot of grit from the car, and it rinsed out real easy for the next dip in the soapy water.
That back yellow foam is a bit of a rougher texture to the front and I used that for the grill on areas that had bugs that where harder to get off.
That might also be a good add on for further Shmitts is to have a double sided one for washing and the other for scrubbing
Final Thoughts
I’m not one for complicating the washing of a car, I like things that are simple to use, work well and don’t feel cheap.
This represented that in every way, it’s a very well made wash mitt that Aaron said will fit any hand. I feel like it will be a good addition to my washing gear.
Snapfish: Share Interstitial:Registration
Out of the package
Final Thoughts
