easy question
KuLex
1994 LS400
what do you use in order to remove leaves and other junk under the hood by the windshield? You know those little grates that, I guess, house some kind of fan or something. My vacuum, which is a normal household vacuum, doesn't cut it. Maybe just a more hard-core vacuum would work. huh?
I had the same problem today. I used my stinger Vac. I do have a shop vac but i didnt see the need for so much power..
thanks guys. The junk is too small and wedged in there too well for me to use my paws. I will try using a vac with some more balls.
