Easiest way to remove coatings
jw3571
What`s the easiest way to remove previous coatings? I applied Optimum Gloss Coat 2 years ago. I`m thinking of trying Carpro Cquartz UK 3.0. Is there a way to get the previous coating off without just polishing?
Polishing is the best way to ensure it’s removed. The prep is always key to maximizing a coatings performance.
That seems to be consensus around here for any LSP. Wouldn’t expect it to last over a year if you could remove with a chemical decon
Zip over the paint with some Essence and that is all you need. Let it sit overnight and come back with a light Eraser wipe and proceed to coat.
If it’s like CQUK3.... I buffed off 2 week old with essence and a green LC CCS pad by hand. A DA should make quick work
