E1 20/20 Glass Cleaner - no streak formula
danforz
It actually works... I saturated both the window and my MF with this stuff. I haven't seen streaking since. Definitely a step up from invisible glass!
I don't really saturate everything that much. I spray enough to wipe the IG around. I try to "scrub" the windows with my WWMF multiple times until the towel and the glass are both pretty dry. Works for me every time.
I find "streaks" are actually just a result of incomplete cleaning.
For example, when you wipe a heavily vinyl-gassed/hazed window, and get streaks, its not really from the cleaner per se (I use Invisible Glass), but its actually you "pushing around" the haze.
The only way to combat this is to get something that can cut through the haze with ease. The only thing I've found that does this is vinegar (diluted). Tinted windows are obviously easier to clean (tinted with tint film, that is)... so if its just a "naked" window you can also combine vinegar with a mr. clean magic eraser to up the effectiveness.
hmmm.... unless they changed the formula a few years ago, i didn't really care for it (if they ever have it on sale somewhere, maybe i'll give it another shot). stoners IG is my main go to glass cleaner...
hmm, weird, maybe I'm the only one. But after having washed my car twice with this stuff (it was REALLY dirty the first time, normal the second) I threw away what was left of my IG.
used 20/20 1st - liked the stuff, tried NXT 2nd - was blown away (just about idiot proof) - can't seem to find NXT on the shelves -so tried Stoners foam - what a load of junk -the 20/20 & NXT maybe couple of "spot" streaks left behind - stoner streaks everywhere - probaly need a complete 2nd application
i really didn't like IG when they were only available in foam...the regular (newer) one is so much easier to use and doesn't streak (unless the glass is really hot or under the sun)...
sprayway here, I find that with alot of things less is better, just a spray on the wet MF and a wipe from the dry MF and I never have problems
