Dumb Question
Cool a Cyclo Polisher. Those look really nice. However they are quite a bit more expensive than the PC. Let us know how you like it.
Hopefully you don't take this the wrong way but are you SURE you can not adjust the speed? I would think a 300.00 polisher would have some sort of speed adjustment. Different jobs need different levels of speed.
If you are right I am glad I never got one of those.
I am pretty sure it's one speed which I did not know when I order it but I keep it anyway. I almost use it everyday and its seem to do a good job. It was my first buffer I every had and I did not know about this web site then. I think the price is high on it too and hope to pick up a PC someday to try out. For some reason lot of airplane and Airstream's detailers use these buffer's alot.
Have you used the cyclo to remove any swirls? A friend has one that I can borrow. It's run off an air compressor. Need to use it on a black car that has swirls bad. Will use it with some 3M 39009? and Meguires 2.0. I just need to get the pads. I figure it will cost me $34 to get the pads I need. I was thinking of getting the PC but I'll only use a buffer this one time and I can borrow it again if needed. Any Comments?
I have not try to remove swirls with my cyclo yet. Maybe someone here might know if the cyclo will do the job but I am not sure.
Thanks for your quick reply. Hopefully someone here can comment. I was thinking of using an air regulator to change the speed of the Cyclo.
I know the cyclo has velcro pads. Are the PC pads velcro as well?
Id rather have the cyclo than the PC but I cant see spending 300 just yet.
*BTW, I had my car done this week by a detailer out of L.I. and the cyclo really impressed me with the results it produced after the compound was used with a high speed. Cyclo :xyxthumbs
