dsms detail- Black Audi S4(first rotary)
dsms
I'll keep this one very brief. S4 DD, lot of correction and my first real go with the Makita rotary
Wash/ wheels
Z7
Megs WB 4:1
Ace Powerstick #401
Megs red clayinners
Methyl Etyhl ketone for the deep inners to remove stubborn grease
Z-AIO topped w/ Z-CS
Clayedtop half of body using Sonus Green/Bottom half Megs red
Interior/Trim
LM strong claner
1Z CP\1Z Reingner
303 cleaner on carpets/APC+ on mats
LGM
Raggtopp on the top
IG toped with Z-CS
Black wow
Noxon +steel wool on tips
Correction
Makita w. 6.5/5.5/4inch LC pads
Infratech CM5300
M105 mixed w. a drop of Ultrafina
Ultrafina
Lights got 106ff
LSP
Z5pro x2
Z8
Powerstick in action
*All 50/50 shots taken without flash to show the brightness and capability of the CM5300*
After just the hood
Lower panels:yikes:
Trunk after first hit of M105
Lower panel
Side hood
Before
50/50 after just M105
After finishing Ultrafina
After correction and UF, No LSP
Finished product
Wow, I can't believe that was your first time with the rotary. You did great work on that Audi clear. The finals look like new! Great job on the wheels too, my boss has the same ones and they are so banged up.
-Frank
Looks great. How many hits did it normally take with the 105? Try using a lower ISO at night, it might clear up the picture a bit (you'll probably need a tripod for it though).
shine said:
It looks great! What did you think of the rotary?
Its awesome, I figured an Audi clear was not the best thing to start with but it needed a lot of correction and time was not on my side so I used the Makita instead of the Flex and im so glad I did. The Makita is really an great machine.
RickRack said:
[quote name='Pats300zx'][quote name='RickRack']Question: What is Infratech CM5300??
Thanks Pat!
Pretty nifty! :)
Oh the CM5300 is a great light, super bright and it has a wide range as well. Its corded too so you never have to worry about the batteries dying on you.:cool:
