togwt
The Old Grey Whistle Test
Provided the paint finish has been rinsed adequately (See Drying a Vehicle ‘sheeting’ water) there should be no dirt residue.
Water is a good solvent but a very poor surface lubricator. Try using a drying aid type detailer (Dodo Juice USA -Time to Dry, Finish Kare - FK425, Autoglym Aqua Wax or Car Plan - Demon Shine) diluted 1:1 with distilled water, which provides lubricity to the paint's surface, in tandem with a damp waffle weave towel (wet, wring and then wipe) when drying your car - this will help break the surface tension of the beads causing the water to run off, allowing the towel to soak up more, and minimise water spots while lowering the friction of the towel over the surface. Do not over apply as this may cause streaking.
Take two waffle-weave drying towels; one soaking wet (a wet towel wicks away more water than a dry towel) and one damp. Wring out the wet towel and use it as your primary drying towel, use this towel to blot- dry and check and rinse the towel often. Wring it out as you go, this will leave smaller wet streaks, which you can remove with your damp towel and it should leave a ‘streak’ free paint surface. This drying technique is excellent for black cars (including ‘soft’ single stage paint that shows every surface mark) but look so good when they are properly detailed.
This process never includes scrubbing, rubbing or applying any pressure whatsoever. The only time that pressure needs to be applied to a paint surface is when you are polishing.
Alternative - dry the car using a surfactant type (ONR) quick detail spray dilution (8oz / gallon) and a waffle weave micro fibre towel.
Why? A surfactant encapsulates any dirt and will provide lubricity to the paint's surface as you blot the paint to minimize adding imperfections. This method will safely remove any water spots that might occur
