I'm installing a rear sway bar tonight and need to drill two holes into a cross-member for mount supports.
What should I use on the inside of the holes to seal the metal and protect against rust? Someone suggested tremclad, but using a spray can seems a bit awkward.
Is there anything similar to anti-siezing comound that i can use (or can i use anti-sieze compound since it's supposed to prevent rust) ??
Thanks
Tim
Thanks
Tim
