512detail
It wouldn`t be a proper comeback if I didnt drop a fresh product review...
Used this past Friday
From the ACC page:
https://www.autopia-carcare.com/dr-beasleys-total-decon.html#.X9Bnk7dMEwA
Dr. Beasleys Total Decon lifts out and removes contamination embedded within automotive paint. Removes iron from brake dust and fallout along with other common contaminants. Reduces need for claying to save time and avoid blemishing the surface.
Penetrates Deeper Than Clay
Clay struggles to pull out the most deeply embedded contaminants. Save time and use Total Decon before claying to get the buried particles clay can`t reach.
Reduces Scratches From Clay
By removing the most deeply embedded particles, Total Decon reduces the need for claying. Less claying, less scratches, which means less polishing work.
Removes Embedded Iron Particles
Total Decon breaks down any iron particles it comes in contact with, whether it`s brake dust from the road or rail dust from trains.
Eliminates Industrial Fallout
Cars in urban areas are riddled with iron and other particles due to nearby industrial activity. With Matte Decon, you can get them all out and start fresh.
Helps Prevent Paint Oxidation
Iron particles embedded in the finish rust (oxidate) over time, eating through it until holes appear. Matte Decon stops this by removing iron before it oxidates.
Preps For Nanooating
When applying nanocoatings like Dr. Beasley`s Nano-Resin Coating, deep contamination must be removed or it will be locked in. Use Total Decon to get it all out first.
Directions For Use:
Holding bottle six inches away, spray paint surfaces evenly, being sure to get full coverage.
Let sit for 30 seconds to a minute.
Wipe away with a microfiber towel
*Multiple applications and longer dwell time may be necessary. Do not apply in direct sunlight.
12 oz.
First off I called Dr Beasley`s directly and waited to speak to a human as I had to have someone dumb me down on the concept of an iron remover you can spray and wipe off and go about your detail.
Well, a human was on the phone in less than a minute. Very nice. Aforementioned human said I can in fact spray and wipe off and go about my day.
Not going to lie, I was Still quite leary.
So I washed the car...she had 551 miles and traveled about 60 to get to me. Then I went about spraying, dwelling and wiping off this thick gel concoction.
It doesnt smell bad, it didn`t bleed the paint, and it was not exactly easy to just wipe off. Perhaps I sprayed too heavily?
I actually ended up doing a n914 rw after and tossed all towels associated with said endeavor afterwards. But I didn`t have any residual issues from cleaning this product off the surface in that manner.
It foamed up some as I wiped off against the areas that touched the hellcat emblems and I ended up flushing those areas out with my ikpro2 and rw diluted to qd. It took a few times, I should have grabbed the hose again in retrospect for just that.
Pics attached from the spray and dwell aspect.
In conclusion:
I`m not sure what to make of this product. Assuming it does as advertised, I could easily make a place for this product on my shelf.
Let`s say I couldn`t do a wash due to it raining outside. Well, Beasley`s told me directly that you don`t even need to rinse this off like a traditional iron remover.
I can tell you it doesn`t just wipe off easily. Unless I`m still a hack, which I suppose is still on the table.
So you might find yourself also asking...
But did it decontaminate? I dont know. All my previous proof of iron removal has been tied to whatever ingredient color changes.
This new paint was still in desperate need of mechanical decon but that isn`t saying much for a vehicle pieced together from mexico to canada and shipped wherever in North America to later be sold.
Would I buy this again? Yes. Why? Because I see a place for it in my arsenal.
Is it worth buying in general? Well, if you are 100% into the iron removal sprays then don`t bother, it will be too strange to absorb.
But if you are like me and can find a place for a little off centered products then by all means pick this up.
I kind of like the thought of being able to chemically decon a vehicle without a hose, but it`s not always the best option.
this product did not negatively affect any plastic or rubber trim, glass or any other surface on the vehicle
Sent from my SM-N950U using Tapatalk
From the ACC page:
Directions For Use:
12 oz.
In conclusion:
