Dp waterless wash
I've got the dp, but haven't used it yet
Q ONR I'd do touchless for real heavy stuff
for just dirty I would pre spray w onr, then onr wash
I'm sorry, I found DP ww horrible. I like a lot of the other DP stuff, but not this. I'm a regular user of Pinnacle, BF, and UWW+ waterless washes
If your doing just a straight Waterless Wash then I highly suggest UWWP+. It is consistently at the top of everyones list. I liked it enough a bought a gallon.
I have used the DP ww several times now. The first couple times were used for just light dusting/dirt and worked great. I have used it to remove bug splatter on the front and it worked pretty good with a little effort. I used it on a few hours old bird bomb and it started working immediately.I just had my car coated with C1 and EXOv2 and drove it 5.5 hours home from Florida with a steady drizzle of rain for about half the trip. The car sat dirty for about 3 days before I could use the DP ww on it to see how the EXO would shed the dirt. The DP ww did not work as I thought it would. It definitely took a lot of effort and several passes on the lower panels to get it clean. I did take all of the factors into consideration though. Also I found that it streaks the glass even after buffing off with another microfiber cloth. The spray bottle, if you choose to buy it, is ok to say the least. But if you have to do a lot of spraying I highly recommend another spray bottle. I will be replacing mine. Overall I like the DP ww but will try something else once I finish up this bottle. Hope this helps.
Just finished my DP bottle, thought it was OK. Then I mixed up a new bottle of Ultima after using the DP bottle up, Ultima is a much better product for me. Cleans better, slicker, and dosent seem to leave the panel as "wet"
Have you tried BLACKFIRE Wet Diamond Waterless Wash?
Im not familiar with the other rinsless wash, but I have a black Mercedes, and even though it requires a little bit of extra work, I love the shine it gives off. Do the other rinsless products have wax in them?
I'm talking about the chemical guy's Ecospa. lol I somehow forgot to mention that.
