Sep 12, 2003 #1 V Vettecor New member My vertical door edge moulding is getting bad and needs to be removed. I know when I remove the moulding it will leave old dried glue. What can I use to remove the old glue? Anything special I should do before I put on new moulding? Thanks Larry
Sep 13, 2003 #3 ntwrkguy1 New member Try using 3M's Wax and Adhesive Remover. That should do the trick. As far as any prep work, just make sure the area is very clean before you install the new door edge guards.
