Does Langka work?
It works, but it is an art. If you apply too much pressure, you'll pull out the entire touch up paint spot. If you are too soft, you can't get it off. But it works. What I do is to use langka first, til it's almost level and then I go at it with the claybar. The clay smoothens the surface and makes it shiny again.
It works fine as intended. Just don't wait too long after you've applied the touch-up paint.
