mikebai1990
This morning, I did my first step of winter prep, 2 layers of Collinite 476, spit shined. When I was washing, I decided to use warm water, because it was cold outside, and I didn't want my fingers freezing up again like last time...
So I put some Meguiars GC into my bucket and filled up with warm water. After I filled it up, I wasn't sure whether I should disturb the soap to make suds or just mix the soap into the water, creating as little suds as possible. Usually, I just hit it with the cold water from my hose. As a result, I get lots of suds, but I find that my solution underneath the suds does not seem to be too slick. So this time, I gently mixed my soap (same amount as usual) into my water (same amount as usual) in hopes of creating a more slicker solution.
So I tried the solution on the van. Although there were not as many suds, the solution seemed more slicker and I think it was better than the situation in which I just blasted the water and got lots of suds.
So... do you guys mix up your soap+water gently, creating little suds, or do you mix up your soap+water vigorously, creating lots of suds? I know that suds does not equal more cleaning ability, but rather more lubricity. However, if I try to make lots of suds, my solution isn't as slick. What do you guys think?
