INTERIOR DETAIL 135 and up
TIME:4.5 HOURS
For the interior mats are removed vacuum very intensive spots are treated then pressure clean extracted and hung to dry @ an angle. The fronts seats are then removed[IF APPLICABLE] tracks are blow out and cleaned,seats are vacuumed and or extracted / conditioned. The cabin personal item are put in a THANK YOU BAG heavy trash is removed then extensively blown out,very intensive vacuumed, spots treated and scrub then extracted with neutralize solution[REMOVE ALL SOAP RESIDUE] and interior wiped down with a solution mix of woolite and water, then condition with meg #40. seats are put back in then the exterior is handwash along with wheel and tires windows clean inside and outside.
