Differences between 3D and HD Product line?
driggett
Member
I see some overlap and was wondering if they are different chemical formulas or the same. There has been mentioned in prior posts that one should stick to the same chemical line for improved performance.
For instance, If using Poxy then use Express for the weekly touch ups since it is the same wax.
Thanks,
Chris
Sent from my iPad using Tapatalk
I can assure you that no product is the same, but each (for the most part) can be mixed with one another due to the same/similar chemical family or ingredients. The 3D line is typically focused on high volume operations (car wash, detail shop, body shops, dealerships, auctions, bulk) and HD is for higher end Detailers and enthusiasts.
Trying to keep the HD/3D names/product lines straight drives me nuts.
I think for the most part HD/3D makes it really easy. HD Cut....HD Polish.....3D Rubbing Compound....3D Finishing Polish...
I'm just glad there's only one brand out there changing product names every year (I'm looking at you Menzerna). They rename some of their new formulas, with the name of old discontinued formulas! :wall
Vega- I must have some mental block or something...can't remember which line my Pink Shampoo or (green) APC or 50:1 Glass Cleaner are from! Guess I oughta work on that :o but until I get it straight I'm gonna [gripe] about having to choose between two names.
Accumulator--if you take a look at the 3D website I think it will clear things up for you.
You'd sure think so, huh?!? I mean...gee, I've always ordered my 3D/HD stuff off the site. As I said, just some silly uhm, processing error on my part. When I'm King of Everything I'll just pick one name or the other and simplify it for myself ;)
Well I know what you mean!! There is only so much storage capacity in the human mind and now that I'm almost considered "aged" in some circles my capacity is becoming filled with pass words, pin numbers and old memories that there isn't much room left for anything else. :angry: :blink: ;)
