It would take quite a bit of light polishing to remove a significant amount of paint. Where you run into problems would be excessive compounding. Compound being like a polish that is much more aggressive (larger abrasives). You just need to be aware of the product/pad combo you are using. Also refine your wash techniques so a major polish isn't really needed more than once or twice a year. I guess I should add that you might have problems if the paint was compounded to a point where it was getting thin before you got the car. An ETG is about the only way to know for sure, and some of the professional detailers here take readings over several body panels before they get too aggressive. Even factory paint jobs seem to vary somewhat on the uniform thickness of paint from panel to panel.MikeWinLDS said:Since polishes remove tiny layers of your car's surface. Will too much polishing over time be bad for your car since it is eating away at it, or will it take an insane amount of polishing over an extremely long time that this just isn't a concern? And waxing is the one that makes the water bead off your car, right?
Which one is responsible for making your car shiny and reflect like a mirror? I've seen people's reflections in their detailing jobs look as though they were looking in a mirror, and others they seem kind of fuzzy in their reflection. I'm not sure if that's because of the car's paint color or the quality of the detailing or something else though.
