Detailing the V - Days 1 & 2
I finally took a Friday off work in order to have three days to dedicate to the long overdue summer prep of my CR-V. The summer sun has already started beating down here in AZ - over 100 degrees Friday, Saturday & expected to continue through the coming week.
I started Thursday night with a wash (PB's Super Slick'nSuds in the foam gun), hit the tires with Purple Power APC (cut 10:1) & a scrub brush to remove old dressing remnants), and used Clay Magic lube & clay. I didn't take any before pics, because it was still looking "good", but it hasn't felt "slick" for some time. Now I could feel the slickness returning :)
Friday I spent six hours in the garage, starting with a once over with Klasse AIO applied with a Megs Polishing Pad on the PC on 2, then boosted to 5. After wiping it off with a PB's Green Ultra m/f (St. Patrick's Day special), I went over the two year old paint very carefully & could not find a scratch or swirl anywhere. So I passed on my planned SSR1 step, and went directly to CK Vanilla Moose applied by hand with a m/f covered foam applicator. Using a DC Prestige Polishing cloth, the VM removed like butter, and the few times the towel folded on itself, it was nice not to have to worry about any edges to cause marring.
Here are two shots taken in the garage after the VM was removed.
Yes, I removed the spare tire before I began :)
Then it was time to start on the trim . . . working in small sections, I bathed it in PB's Trim Restore, applying it with a 1" foam paintbrush & going over & over to keep it even, then leaving it for 10 minutes, and buffing with an old m/f. On the harder plastic on the doors, I topped it with VM to see if it would help it hold up to the AZ sun.
Then it was on to applying the first layer of PB's EX-P with a Megs Foam Finishing Pad on the PC set on 2. I removed it with PB's DMT ("sister towel" to Dwaynes PPC), the EX-P wiped off like butter.
After that, I quickly treated the tires to a rubdown with PB's Bold 'n Bright tire dressing, backed the V out into the driveway for the following pictures:
Yes, those really were clouds up in the sky!!
Saturday morning I got up early & applied the second coat of EX-P (yes, I know, only 12 hours "cure" time), but I wanted it there before I took the V out for the day :) Once again, I used Megs foam finishing pad with the PC set on 2 & this time I removed it with a SMP Soft Edge MicroFiber towel - another winner in my book :)
A very pleasing combo :)
When we got home from our Saturday morning errands, I stopped in the driveway for the following pics of the V with two coats of EX-P.
Today I'll give it the third coat of EX-P (24 hours cure time this time) and start counting the days til "waxing season" :tumblewee
norahcrv
Nicest CRV I've seen in a while.
With your climate I think 12 hours is plenty. :grinno: Beautiful job. My son and his girlfriend are out in the Phoenix area as traveling nurses enjoying the warmth.
Sludge
Great job! Best looking CR-V out there! I may have to revisit VM on my paint...I tried it twice last summer and I just couldn't get to work for me. I also like your clean, deep black trim :bigups
Would you be able to elaborate on how you used "Purple Power" on your tires? Do you spray and let sit? agitate while its on? TIA and great job again :bow
MCA
Wah, wah, wah, 100 degrees in Phoenix, we hit 102 in Dallas back in April and this past Tuesday, although it was *only* 96, the heat/humidity index was 109!
.....of course, when y'all are knocking on 120 and it is only 95 here... :LOLOL
The paint on your CR-V looks dripping wet! :drool:
