KC@detailien
Came a badly injured patient with lots of Dermatology issue
BTW
do you really need to invest in a very expensive camera to do photo shoot during car detailing or are you a DESKTOP photographer who spent hours in Photoshop-ping
No offense the usual camera we usually use is the most affordable off the shelf available....when the detail is right & done correctly everything will be picked up
needless to use any expensive stuff to cover it or bring it up
PICTURE saves all the say
with full of Dermatology issue
deeper leporsy like infested issue
how can one go and not cared for such an issue
when the pre-clear coat days (1K paint) usually requires a lot of care and attention, as it is easily stained or oxidizes.........so
the older generation driver endedd up with alot of waxing job to maintain a good health on their car paint, something they will do on special occasions to provide a little extra shine.but actually something that should be done on a regular basis.
now with the Clear coat (post Era) lesser effort requires to maintain a good and healthy paint, as it has a protective coat against wear and tear, still many had the misconception (treating their ride like BULLET PROOF). No No mentality!!!!!!
Dermatology issue + Deep Scratches
tropical issue with Dermatology issue
The exterior of your car needs regular care as well. While neglecting the paint job may not lead to mechanical performance issues, it will result in a lower resale value, just like if you never changed your oil or got a tune up.
man best friend signature
under proper lighting....stains are captured
more closed up pic
how to restored...it is like fungus.......
ta da after restorations
before
during deeper correction
a 50 % /50% comparission
tada
lower body
scratches
upper body
man best friends
before
tada
deep issue
became no issue
infested
restored and healed
chemical used and stained
https://lh6.googleusercontent.com/-xsJnquNr6nE/UaNrOngENKI/AAAAAAAAOR0/v7961LalruA/s512/IMG_1096.JPG/img]
after paint correction and alien coated
[img]https://lh3.googleusercontent.com/-RlpNqF2BD08/UaNrQzMQbNI/AAAAAAAAOR8/K-Pu2Qzpafo/s512/IMG_1133.JPG
more damaged ill looking paint
now after restorations and ALIEN COATED for optimum protection
what / where to avoid
- Road side car wash -
- Parking under tree (saps)
- carefree parking (as where and when you like) only inviting abuser to scratch your car
- partial roofing - tiles wash down stains
- construction area (misty debris and paint sand blasting to your car) or chemical blow over
- leaking roof - avoid mineral deposit aka permanent deposit
what to do
weekly wash
montly wax / or get it coated for permanent protection
moving to engine bay detailing
tada a 3 years old honda looks like just rolled out from the show room again
before
before
before
touch up of paint chipped prior coating
tada
Dermatology is the branch of medicine dealing with the skin and its diseases, a unique specialty with both medical and surgical aspects. A dermatologist takes care of diseases, in the widest sense, and some cosmetic problems of the skin, scalp, hair, and nails.
BTW
more closed up pic
before
tada
lower body
scratches
upper body
man best friends
before
tada
deep issue
became no issue
infested
restored and healed
what to do
weekly wash
before
before
before
tada
