My buddy's 4Runner has been through the war. Left outside 24/7 with no protection whatsoever, not even through the car wash. My first time working with ss paint and was pretty easy to work with, except the part where I had to wash pads after doing 2 panels because of paint transfer. There were also alot of areas on the roof with bird poop etching which are through the paint and one bad area on the hood.
Process:
Wash - ONR with PakShak Ultra Plush MF, 2 buckets
Clay - Clay Magic, Blue (Used 1/2 the bar!)
Lube - ONR
Got to play with the Festool RO150 FEQ
Polish - Menzerna IP, 1/2 LC CCS White (went through 2 pads) @ Rotary 6 on the Festool. Needed 2-3 passes in some areas
Polish - Menzerna IP, 1/2 LC CCS Yellow via Festool Orbital @ 6
Finish - Optimum Poli-Seal, LC CCS White
Wax - CG Pete's 53', WOWO using foam applicator and PakShak MF
Tires/Wells - Megs Instant Shine Aerosol
Trim - PB Trim Restorer & Pace Edwards Vinyl Cleaner (Thanks Marvin!)
Interior - 303 Spot Cleaner & Aerospace Protectant, PE Vinyl Cleaner
Here are the BEFORES:
Process:
Lube - ONR
