Detailed: 2004 Winnie (Round 2)
justin30513
Mobile Detailing Services
I did this motorhome back in August with the help of my brother. I had to do this time on my own. The owner own's the local marina and I do all 9 of his rides. I've posted most of them on here. He is getting ready to head out to Colorado this weekend on a hunting trip and wanted it washed and waxed. I got up at 6 this morning and headed out. It was freak'n 38 degrees! I didn't realize too that the sun was now coming up an hour later here. So I got there and sat in my truck and drank some coffee.
When daylight broke, I started washing it. Using my brush, I broke it down in sections. It had mostly road film. I was amazed to see some beading still from the Meg's Cleaner Wax I used almost three months ago on it. After rinsing, I strapped on a Stihl backpack leaf blower that the customer had in his garage. WOW! I thought my 160lb. body was gonna come off the ground! I dried it and then towelled it down with the aid of a 4 foot step ladder.....I'm tall. He wanted durability so out came the Collinite No. 845 and Collinite Super DoubleCoat Auto Wax #476.
Here's the entire process....
Start Time:
7:30am
Finish Time:
2:00pm
Payment:
38ft. X 12.00 per foot=
456.00
Washed with Meguiar's NXT
(Used my wash brush and add one cup of Meg's APC to the 5 gallons of water)
DP's Mild Swirl Remover
(EDGE2K Yellow Pad at a #5 PC setting)
I used this mainly on the front of the coach. There were multiple layers of wax applied by the customer in hopes of easy bug removal. I wanted a clean slate for the 845 and Double Coat. I also polished up the side compartments and handles due to mild tree branch scratching.
Collinite's No.845 Insulator Wax
(EDGE2K Blue finishing pad at a #4 PC setting)
I've learn to pre-lube the pad well with water for No.845 to go on easy. Once my pad was well loaded, I could go far with very little of this wax. I put it on thin and even with overlapping swipes. I let dry for 30 minutes while I did the other side. This time, it came off so easy by hand and Cobra MF. There was a very slick feel to. I also made sure to shake the bottle very well......for about 5 minutes. I believe this helped since it seemed thinner then when I used it last week. I even used it on the mirrors.
Collinite's Super DoubleCoat Auto Wax #476
(Applied and removed by hand.)
After letting the 845 sit and cure for about 2 hours on the front, I came back with this wax. Once again, I wet down my MF applicator pad. This time with Wolfgang's Spritz Detailer. This really help the product to go far. It went on very smooth. I let haze for 30 minutes and removed easily by hand. I wanted the ultimate protection on the front and believe I may have it here.
Awesome work Justin!
I think that even though a motorhome is a beast to detail it would be fun. Nice work and great reflection shots.
:2thumbs:
It's not as hard as you think once you have done a few. You just break it down into sections. At least you don't have to do a nasty interior!
WOW..........WOW...........YEAH
You always do outstanding jobs and your write ups are very informative.
Keep up the crazy working man respect
The before pics looked very nice actually. I was wondering how you could make it look better....then I looked at the afters. Once again you exceeded what I thought possible. Excellent job, just excellent.
First I thought you detailed a Winnie the Pooh. Then I click on the link, wow! As I viewed your photos I kept thinking this is not a motorhome, it's more like a tour bus. Amazing work Justin, the paint is just glowing. Did you use a couple of quarts of tire dressing to do those monsters? :) How do you like the Edge 2000 waffle pads? I've just been using the smooth ones so far. Great pads, the wool ones work very well too.
I used about one container of Armor All Tire gel. Goes alongggg way.
Nice work. Was that motorhome base/clear or a gelcoat. I have done a couple of motorhomes all gelcoat mostly white and when it is oxidized man is it a lot of work.
