:rofl Here is some of the Q & A::lmfao
Q: Will this work with my convertible?
A: If it has a solid top you can use it.
Q: can I get away with only buying one, for two cars... and switch which one I put it on depending on my mood?
A: Once you install the sunroof if you take it off, the sunroof won´t damage your car, but it will not be able to use on another car, this is for prevent burglars to steal it.
Q: Can this be put on other parts of the car, such as the hood or trunk lid, or do you have to put it on the roof? Does it fit all models? I have a Dodge Stratus right now, but I'm probably gonna get a Dodge Viper pretty soon.
A: Yes, you can put it on other parts of the car. If fits all models.
Q: How does the sun get thru the roof?
A: The sun won´t get thru the roof, because the self adhesive sunroof is a sticker that gives your car the look of a real sunroof, but you don´t make a hole to the car.
Q: Does this sunroof come with all of the installation tools necessary for proper install?
A: This sunroof is ornamental, it´s only a sticker that you put in your car´s roof and gives your the look of a sunroof, but you don´t make any holes to the car. It comes with step to step instructions, it´s very easy because you only have to put the sunroof sticker in the car.
Q: how much horsepower does this add?
A: The self adhesive sunroof doesn´t add any horsepower to the car.
Q: I would love to have a sunroof - is it guaranteed to be waterproof? do you have pictures from the inside of the car after install?
A: This sunroof is ornamental, it´s only a sticker in the car´s roof, and it´s waterproof and weatherproof, there´s no need to make holes on the car. From the inside the car will look the same since you´ll only be attaching the sticker sunroof in the carroof.
Q: What is this magnetic technology? so is it a sticker or a magnet?
A: It´s a magnet and a sticker so it can stick better to the car.
Q: Is this the kind of sunroof that slides back or only pops up?
A: This sunroof is only ornamental, it´s a sticker that gives your car the look of a real sunroof, but it doesn´t slides back or pops up.
Q: Does the product come with instructions on how to cut the hole in the car roof?
A: This sunroof is ornamental, it is only a layer of stickers that attaches to your car, without any holes and gives the car the appearance of a sunroof.
