Deep Gloss Auto Salon
360 Challenge Stradale
* I was sure I had posted this already here on Autopia but I can't seem to find it
The Challenge Stradale is a 360 Modena on a double dose of steroids from the planet Crypton.
The exterior changes from other 360s are subtle, but that is where the subtlety ends. One of Mr. Moruzzi’s goals with the Stradale was to shave three seconds of the 360’s Fiorano lap record. Suffice it to say, he and his team were successful.
Once you enter the Stradale it becomes very evident that this car is all business and shed as much weight as possible. You won’t find carpet, in its place is rubber floor mats. The seats are carbon fiber and this specimen has the wonderful Alcatara leather. You also won’t find a stereo in the Stradale, the music is the purr of the all aluminum V8 that hits 60mph in 4.1 seconds and stops by means of the Enzo carbon brakes and changes gears in 150 milliseconds.
Enough of my banter, on with the show.
As always, the wheels were the first items attended to. Due to the sensitive nature of these carbon/ceramic brakes, careful product selection is needed as to not induce damage to them and render them useless. For this task P21S wheel gel was used with various brushes
Below is an action shot of me using my beloved Raceglaze XL wheel brush. This tool won’t spit back on you like many brushes; it is sturdy, effective enough to clean yet, wont scratch and, it’s very thin. I mention it being thin because this is my favorite feature, as you can see it even fits between the very small clearance of the rim and the caliper.. Love it
After the wheels were done it was time to do something about bugs that met their death on the front of this stallion and the minimal road tar that was on the lower body panels. The front and lower portions of the vehicle were showered with water via pressure washer and then, treated with 1Z Einszett Anti-Insekt Bug + Tar Remover. It was left to dwell for 3 minutes and then pressure washed off.
From there the entire exterior of the vehicle was showered with water via pressure washer to dislodge as much debris, dirt, contamination as possible. After showering with just water it was time to use the foam cannon. A strong concoction of several soaps and cleaners was sprayed onto the exterior and left to dwell for several minutes.
After dwell time
After the foam dwelled it was then pressure washed off and foamed again, this time with Duragloss #902.
It was left to dwell and then a proper 2 bucket wash was performed using Duragloss #902 and an Uber sponge from Detailers Domain.
After washing every square inch of the exterior body panels, the vehicle was pressure washed clean and then further decontaminated using Riccardo yellow clay and Optimum No Rinse as a clay lube. While claying I was rewetting the vehicle to prevent water from dying on the body panels.
After claying, the entire vehicle was blown dry and then residual water was blot dried using high quality chemical guys micro fibers.
Below are some post wash pictures. As you will see there was a solid mix of holograms and swirls/scratches throughout
All sensitive bits were taped up to protect them from damage and it was time to get to business… Paint correction!
As always, a test section was picked to determine the best and least invasive course of action that would get this paint back to its glory. F-Cars of this vintage usually have paint on the softer side of the scale and this one was no different. I called Mr Willis to ask him a question about the racing stripe, thanks for the time!
The paint correction process was a 4 step process for the areas with deeper inclusions and a 3 step process for all other body panels. Below are my paint correction steps:
• Body panels with severe damage were polished with Menzerna Intensive Polish and orange Lake Country Pad
• All panels (including aforementioned panels) polished with Menzerna Intensive Polish and white Lake Country Pad
• All panels polished with Menzerna 106FF and black Lake Country pad
• All panels jeweled with Menzerna 85rd and Lake Country no cut red pad for high gloss
91% IPA wipe downs were performed to ensure that the correction observed was true and that no carrier oils were acting as unintentional fillers.
The test panel was determined the first night of delivery and inspected under many different light sources.
Before and afters at various phases of correction process:
After pictures at various stages of correction process with various light sources:
Brinkman:
Fenix:
Camera Flash:
Halogens:
The next morning, I pulled the vehicle out into the sun to validate my correction process steps were robust. Below are pictures of the “in sun inspection”.
And another later in the day:
The engine bay was also given much attention and really was brought back to life.
A thorough wipe down with a spray bottle filled with ONR was the first step.
The carbon fiber drain channels had lost all clarity and shine. The carbon fiber air intakes, while not as bad as the drain channels were also treated in a similar manner as follows:
Duragloss #501 was used to chemically clean and seal the carbon fiber.
Hand polishing with Menzerna #205 and a white polishing pad was done.
Carbon fiber areas were then sealed with Zaino AIO and Z2
The reason #501 was done was because we thought that would be all it needed. After it was completed by my assistant, he called me over to inspect and I then determined that a chemical cleaning was not sufficient and that more life/clarity could be given to these areas and thus, the hand polishing and Zaino treatment was done.
The metal exhaust can was hand polished and then topped with Surf City Diamond Edge Metal Dressing. All rubber bits in the bay were dressed with 303 Aerospace protectant.
Below is a picture that is representative of the condition of the carbon fiber drain channels in the engine bay
After:
Before:
After:
Full After Shot:
